February 11, 2004, 12:50 |
help on AMG soler error
Hello everyone,
When I runing POWER LAW or Quick scheme in my model, fluent give me the error: diverge in AMG solver: X-Momentum. I could not figure out what cause this problem. Does anybody give me a help on this error? For my case, first order and second order scheme works well. Because my grid is T-Grid, so I think power law scheme is better for my simulation. Any helps are appreciated. Thanks. Zwdi |
February 11, 2004, 13:18 |
Re: help on AMG soler error
Check you boundary conditions to see if it is well defined.
February 11, 2004, 13:42 |
Thanks, Wang. I used the same boundary conditions as upwind scheme. Do you mean if I change discrete scheme(upwind, power law, quick), I should change boundary conditions? Add one point: I use RSM turbulent model.
Zwdi |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
