VISUAL6.0 C++
Old   February 20, 2004, 18:41
Default VISUAL6.0 C++
STK
HI !
I;VE INSTALLED 6.0 C++ AND AFTER RUNNING VCVARS32.BAT AND LAUNCHING FLUENT FROM MY RUN DIRECTORY IT SEEMS THAT THE BAT FILE DOESN;T HELP COMPILING THE SOURCE CODE.FROM EXPERIENCE THAT DOESN;T MATTER WITH .NET VISUAL C++.WHAT I MUST DECLARE TO WORK WITH 6.0 .DOES ANYBODY HAS VISUAL 6.O TO TELL ME THE PROCEDURE FOR COMPILING BY COMMAND LINE?
Old   February 21, 2004, 05:06
Default Re: VISUAL6.0 C++
Rob Hart
Have you read chapter 7.3 of the UDF manual?
If so, were there any bits you didn't understand?
Are there any particular error messages you are getting that might give somebody a clue as to where to start with your problem?
Also, do you have a key (probably to the left of you keyboard) that has "Caps Lock" printed on it? You will never be able to write a UDF if you can't write in lower-case.
Rob
Old   February 21, 2004, 15:07
STK
OF COURSE AND I HAVE READ 7.3 CHAPTER! I KNOW HOW TO COMPILE I HAVE DONE IT WITH VISUAL .NET C++.
THE PROBLEM IS WITH VISUAL 6.0 C++.WHEN I AM GOING TO BUILD THE SOURCE FILE,I DON'T GET ANY MESSAGE (AS I SHOULD GET):GENERATING THE CODE...AND THEN WHEN I COMPILE, THE SYSTEM CAN'T FIND ANY FILE OR FOLDER. I TOLD YOU I RUN VCVARS32.BAT AND THEN I LAUNCH FLUENT FROM MY DIRECTORY D:\CFD (RUN DIRECTORY).
IF YOU HAVE VISUAL6.0 C++ PLEASE TELL ME THE WHOLE PROCEDURE, ESPECIALLY THE COMMAND LINE PROCEDURE.THE ABOVE PROCEDURE,WHICH I DESCRIBED,I FOLLOWED AT .NET C++. DO I HAVE TO ADD SOMETHING FOR 6.0 C++?
BEST REGARDS
