help in residence time calculation
Old   November 8, 2010, 00:10
Unhappy help in residence time calculation
xinlei hu
hoolei is on a distinguished road
hi everyone
I am doing a simple modeling with a inlet, a chamber and a outlet for resident time distribution. The fluid is defined as water(or water and O2). I do it by the tutorial but i can not got the result:
Procedure:
1.Activate species transport model using the Define:Models:Species:Transport and Reaction panel.
Q: When I activate the species transport model, the mixture must be selected, how can i find a mixture of h2o and h2o?
2.In the Define:Materials panel, create a new fluid species “tracer” with the same physical
properties as the test fluid.
Q: I can not manage to creat the new "tracer" with the physical properties as water.
3.For the mixture material in the Define: Material panel, select following properties.
a. Mixture species: tracer and test fluid
b. Density: volume-weighted-mixing-law
Q for there was no tracer created, or the created tracer did not appear in this panel, so I can not do this step.
4.In the Define: Boundary Condition panel, set the tracer mass fraction at the inlet equal to zero.
Q: where is the tracer mass fraction, I can not find it?
5.Disable the tracer species equation in the Solve:Controls:Solution panel.
Q: can not find the "tracer species equation"
6.Define a Surface Monitor to monitor the area-weighted-averaged concentration of tracer mass
fraction with flow time at the outlet. Activate the Plot and Write options to write the monitor data to a
file.
Q: can not find the "the area-weighted-averaged concentration of tracer mass
fraction"
may anyone help?
great thanks!
hoolei is offline   Reply With Quote
time step calculation david FLUENT 1 May 7, 2008 01:36
Residence time contours? Carlos FLUENT 0 February 8, 2008 17:42
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 15:15
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
