How to Grid the 3mm thick Swirl plate
Old   February 25, 2004, 00:10
Default How to Grid the 3mm thick Swirl plate
chetan shah
I have problem of heat transfer through a combustor woth 3mm thk swirl plate welded on outer surface, acting like fin. When i am giving a mesh to that sheet volume in Gambit, it took to much time for dense grid. & lower dense grid I can not apply.
Please guide me for the type od grid, which I can apply or guide me about the procedure.
Can size function solve the problem??
Thanks all
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Troubles modelling flow through a grid Hans Klaufus CFX 1 June 28, 2000 16:43
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
