How to free memory after running Fluent ?
Old   February 27, 2004, 03:52
Default How to free memory after running Fluent ?
David
I use Fluent as a calling subroutine in my program. And the next step is based on the resulting data calculated in Fluent. But the program always prompts that" program can not access the resulting data file because another program is still using it". I guess the reason is maybe the allocated memory to the data file is still occupied by Fluent. So, I want to ask how to free memory after the run of Fluent. The software platform is Compaq Visual Fortran 6.5.
Old   February 27, 2004, 03:59
Default Re: How to free memory after running Fluent ?
David
BTW: I had used compiled UDF in Fluent to export the result data file I wanted.
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
Memory of PC for running fine mesh size sepidecent Hardware 4 August 16, 2011 20:43
Valgrind claims invalid free when running icoFoam from OpenFOAM 1.6-ext andrewryan OpenFOAM Bugs 3 March 30, 2011 08:00
Running fluent in UNIX L3munoz FLUENT 10 August 26, 2009 04:59
running Fluent on a DUAL CORE system Ralf Schmidt FLUENT 3 June 20, 2006 10:21
