B.C. on heat flux
Old   March 9, 2004, 23:30
Default B.C. on heat flux
mottar
I am modelling a very simple 2d parallel plates with a fully developed laminar flow through it. The bottom plate is heated uniformly while the top one is adiabatic. What I find strange is when I change the value of the heat flux, the Nusselt number on the bottom plate is changed too, which should be a constant! So would somebody help me to point out where my problem is? Thanks!
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
Constat Heat Flux B.C. Kiumars Main CFD Forum 1 October 19, 2005 09:16
problem in transcient heat flux b.c in UDF phani FLUENT 3 April 9, 2003 00:58
