March 23, 2017, 08:37 |
What is the minimum value for URF?
Prikane
Rep Power: 10 |
Dear colleagues,
I am working on problem in which I need to include dynamic mesh option. Pressure in this problem is really high (it goes above 1 GPa) and high pressure produces fluctuations in the UDF for dynamic mesh, more specifically in the main equation which calculates node positions at boundary. Pressure fluctuations are ripping my mesh apart and I have occurrence of negative cells. So in order to make numerical calculation more stable I need to apply URF for pressure. My question is: What is the minimum value for URF? Does anyone know some recommendations from literature for the lowest URF? At the moment, I am using value of 0.0001 as URF for pressure. With this value I do not have occurrence of negative cells but I am afraid it is too low and I will never get solution convergence. Thanks in advance, Prikane |
fluent - udf, lowest urf, minimum urf, urf |
Skewness , Minimum Edge Length and Mesh Quality in FLuent | ViLaks | FLUENT | 2 | March 2, 2017 05:57 |
Minimum PDF enthalpy exceeded during injection, without physical explanation | Daveo643 | FLUENT | 1 | November 2, 2015 11:47 |
Get the maximum and minimum pressure in the domain(In parallel calculation) | xh110120 | Fluent UDF and Scheme Programming | 4 | October 10, 2014 08:06 |
AMI: Minimum patch weight decreases with time | lordvon | OpenFOAM Running, Solving & CFD | 2 | September 3, 2013 12:39 |
Setting a minimum temperature value | WillemvdM | OpenFOAM Running, Solving & CFD | 0 | February 3, 2010 02:37 |
