Error while reading CFD Post file exported from FLUENT
Old   September 3, 2016, 19:25
Default Error while reading CFD Post file exported from FLUENT
Amjad Farah
amjadfirst is on a distinguished road
I have a simulation of a simple tube with supercritical water, and in low heat fluxes and low temperatures I can export the solution data to CFD Post and open it with no problems. When I run the same simulation but change the boundary conditions to high heat fluxes and resulting in higher temperatures (close to 900 K), I export the data again to CFD Post but when I try to open them it gives me this error:
ERROR
File "file name" does not exist or is not readable.
I'm completely flummoxed by this weird error, I can't seem to find the root of the issue and I can't find a similar situation online. Any help is appreciated.
Thanks,
Amjad
amjadfirst is offline   Reply With Quote
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
