-> (command)
Old   March 29, 2004, 06:18
Default -> (command)
Vasilios Papaioannou
Hallo!
How can i interprete the command "t0=t->t0;" and "t1=t->t1;"? When i run fluent it shows error in the lines containing the above. Can i bypass compiled UDF and alter these command in an interpreted understandable way?
Thank you.
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 04:41
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
