helP...UDF for h
Old   April 3, 2004, 13:02
Default helP...UDF for h
Amir
Hi I want cooling a ball with flow stream.my rpoblem is forced convection.wall tempreture change wiht time.(unsteady) how can I difine UDF for wall of ball? what is the equation that I must use it to calculate "h"( convection heat transfer coeffienct)? tank yuo. Amir.
Old   April 7, 2004, 00:29
Default Re: helP...UDF for h
FJ
To define temperature of the ball, DEFINE_PROFILE is suitable.
If the mesh around ball is very fine(Y+ < 5), the "h" is calculated automatically and this equations are showed in User's Guide. We can not define this "h" as default function except via UDF.
Thank you
FJ
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
