Dynamic Meshes with Mixture Model
Old   April 3, 2004, 21:32
Default Dynamic Meshes with Mixture Model
cfdtoy
Hello
Has anyone successfully worked with a mixture multiphase model with dynamic meshes option !? Looks Like Fluent has some difficulty in computing Mixture Models with Dynamic Grids !
Any comments is well appreciated.
Thanks
CFDtoy
Old   April 6, 2004, 02:14
Default Re: Dynamic Meshes with Mixture Model
FJ
It's no problem even VOF model.
Mixture Model is not complex model in Fluent multiphase models. If it is Euler-Euler or Euler-Granular, it will be very tough calculation without MDM.
Thank you
FJ
Old   April 13, 2004, 13:32
CFDtoy
Hi
FLuent is not compatible with VOF Model and Dynamic Grids !
Only Mixture and Discrete Models are..but looks like Fluent simulations have some intricate problems when predicting cavitation and other other phenomena associate d with multiphase flows.
thanks
CFDtoy
Old   April 13, 2004, 21:16
FJ
Yes, you are right. They said "Fluent is not compatible with VOF Model and Dynamic Grids".
But I don't think so from those equations. So I checked and the results were O.K.
All phases mass and volume became conservation and it good agree with the experimental results.
From those equations of Dynamic Grids, I understand that both VOF and Mixture model is no problem because their scalars transport based on the mixture velocity.
For Euler-Euler model ,I said it's O.K but I reconsider the equations again , It's maybe impossible.
Thank you
FJ
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
Mixture model for Multiphase flows sandisk FLUENT 0 January 23, 2011 18:05
Plz help, How can I enanble the Dynamic Smagorinsky-Lilly SGS model? fireman FLUENT 0 November 10, 2010 12:25
air and water vapour mixture - multiphase model Saba FLUENT 0 February 10, 2009 12:05
Question about Mixture Model cao wei FLUENT 4 March 31, 2003 09:28
