i begin use udf please help
Old   April 19, 2004, 03:54
Default i begin use udf please help
tana
i start use UDF .Now i have cas file and udf file. i can not run udf .i need to know which directory i must save udf file??? please tell easy thank a lot
Old   April 19, 2004, 20:30
Default Re: i begin use udf please help
Allen
Hi tana,
You shuold make sure that your UDF source file are in the same directory containing your case and data files.
Regards, Allen
Old   April 20, 2004, 05:48
Alamgir
Make sure ur udf files are in same directory.. and also interprete the file using DEFINE>FUNTION>IN.... OR COMPILE
then u could have it ready whr need... just click on pull down arrow and select the ur udf.
Alamgir
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
