UDF 3D inlet b.c. problem
Old   May 24, 2004, 12:34
Default UDF 3D inlet b.c. problem
Andrew
I am trying to define a 3D parabolic inlet velocity profile using a UDF. My udf compiles (as an interpreted udf) without any errors. It then becomes an option to pick in the inlet boundary condition drop down list. However, when I try to initialize the flow, the program freezes. Has anyone experienced this problem, and if so, did you find a solution?
Thank you,
Andrew
Old   May 24, 2004, 15:00
Default Re: UDF 3D inlet b.c. problem
zwdi
Hi
What "program freezes" means?
Zwdi
Old   May 24, 2004, 15:55
Andrew
What I mean when I say the "program freezes" is that the simulation cannot be started. In the 'initialization window' I select initialize flow from inlet condition and that is as far as I can get. It doesn't initialize the flow or report an error. It just simply locks up - doesn't do anything. I cannot select another option, it won't respond to anything. All I can do is kill the program in the unix shell.
Old   May 24, 2004, 17:04
Ryan
This is kind of a roundabout way of getting around the problem, but you could manually write a profile in a text editor and read that into FLUENT for you boundary condition.
Old   May 25, 2004, 04:24
ap
First of all, check if the problem happens even without the UDF. If not, try to post the code you're using.
If you do a search on this forum, you should find a UDF for a 3D parabolic velocity profile I posted in an answer to another question.
Hi
ap
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem in compiling property(density) UDF satish2968 FLUENT 3 October 31, 2008 15:06
Pressure profile UDF for unsteady-state problem? Mohsen Keshavarzian FLUENT 2 August 20, 2008 04:22
UDF PROBLEM anant FLUENT 2 January 17, 2007 00:15
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
