bullet simulation
Old   April 30, 2004, 11:34
Default bullet simulation
arthur
i want to simulate flow around bullet, but i having problem for gun and bullet geometry such cleareance/gap between bullet and barrel, than pressure, energy, etc. can anyone help me??? I appreciate all replies. thx
Old   May 4, 2004, 12:14
Default Re: bullet simulation
Evan Rosenbaum
There will not be any gap between the bullet and the barrel of any modern weapon. You can get bypass flow through rifling though. The bullets start out slightly larger than the bore diameter and get squeezed into it. Pressure can reach or exceed 60K psi (414 MPa), depending on the design. Energy can be up to 15K-20K lbf-ft.
Old   May 5, 2004, 09:04
arthur
are you sure??? so i can say that bullet diameter larger than bore diameter, then the bullet's motion can make inner surface of barrel scratch.
Old   May 5, 2004, 09:14
Evan Rosenbaum
The bore is much harder than the bullet (steel vs. bare or jacketed lead), so the bullet isn't going to damage the barrel. It is the other way around. Eventually the bore of the barrel will erode somewhat, but that would typically take tend of thousands of bullets.
Old   May 8, 2004, 02:56
arthur
thanks for your help, can you help me an example?? i appreciate it much. thanks again ;]
Old   May 11, 2004, 12:39
Evan Rosenbaum
I'm not sure what kind of example you want. I'm fairly sure that FLUENT is not capable of solving the problem you are asking about. Internal ballistics is extremely complex and involves a lot of mechanical behavior that FLUENT can't come close to simulating.
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
