time taken to update solution in unsteady flow
Old   May 6, 2004, 04:50
Default time taken to update solution in unsteady flow
phil
Hi, I am running an unsteady simulation, the interations are running at a acceptable rate however it takes a very long time to update the solution. Is there anything i need to do to speed this up? is it possible i may be trying to update a solution over the network? what is the file that fluent is updating?
Old   May 6, 2004, 12:03
Default Re: time taken to update solution in unsteady flow
co2
Dear phil:
are you writing a lot of .out files ? monitors ?
if so, if you are doing it per iteration, that might be the culprit -- just a wild guess.
Old   May 6, 2004, 12:05
phil
thanks for the reply but unfortunately its definately not that, i have no monitors of any time and the iterations are progressing well it just takes a lot of time to update the solution at the end of every timestep
Old   May 7, 2004, 08:22
co2
are you writing to network drive or local drive? try local - that may give you better results.
Old   May 17, 2004, 07:33
kethireddy
Hi best thing to improve the convergence rat is just increase underrelaxation factors(ideally to 1) .. kethireddy... rwth-aachen.. Germany
Old   May 17, 2004, 10:08
ozgur
Are you using VOF model? If so, that should be the reason of long updating time because of the VOF sub-time steps.
Old   May 17, 2004, 10:12
Phil
yes it is VOF
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
time step for unsteady turbulent flow vishnu FLUENT 4 December 11, 2006 03:25
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
