enhanced wall
Old   May 8, 2004, 21:41
Default enhanced wall
co2
hi all,
I am running some unsteady calculations. Flow is buoyancy driven. Time step is 1 sec. I am using std k epsilon with enhanced wall.
I am checking on y+ from time to time and I see that it is hovering around 2.5 to 4,5 etc. At one occasion though it went upto 10. ---- IS THAT OK? OR IS IT NECESSARY TO KEEP Y+ AROUND 1 all the time?
Old   May 10, 2004, 10:46
Default Re: enhanced wall
zachi
you should keep you y+ value at 1-4 but in my opinion a value of 10 is very high.
regards
zachi!
Old   May 20, 2004, 12:22
ahad
Using the Enhanced wall treatment as wall function at least needs to have about 6, 7 layer grids inside the viscous sublayer. The recommandation of Fluent user guide is that yplus should about 1 but it also says that it can be also about 4 or 5. I was working on enhanced wall treatment for some month and I published a paper which showed that using EWT option gives acceptable results for heat transfer of impinging jets. any in a complex flow and stagnation area of this kind of flow the y plus had to be equal or less than one. I recommand to solve your problem with different size of grid and validate your results with different y pluses.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
