Bubbling Fluidized Bed reactor burning biomass
Like Tree1Likes
  • 1 Post By Mattias
Old   June 3, 2004, 08:24
Default Bubbling Fluidized Bed reactor burning biomass
Mattias
Hi everyone!
I´m simulating a Bubbling Fluidized Bed (BFB) reactor burning biomass. The geometry is 12 m high and 3*4 m wide (800 000 cells). I have set my boundary at the bed surface to avoid modelling the dense bed. The splash-zone and freeboard is modelled as a porous zone with a momentum resistance. The fuel is modelled as gas (CH4 and CO) and the combustion as a 2 reaction mechanism. I´m using the eddy disipation model to calculate the reaction rate and realizable k-e turbulence model.
My problem is that the reaction are going to fast. I have a complete burnout of fuel before it get to the overfire distributors and therefore the temperature in the lower part of the furnace is to high while in the upper part, the overfire air cools the gases down to much.
Any sugestions? Is the EBU-model better or should I use a more complex reaction mechanism? Or is a 2 phase model better?
Thanks! /Mattias
Duofeng0214 likes this.
Old   June 3, 2004, 14:19
Default Re: Bubbling Fluidized Bed reactor burning biomass
Ryan Zarnitz
If your fuel is completely burning out before the overfire air inlets, then it's possible that you have too much undergrate air for your amount of fuel. I suggest checking on that, provided that you are confident about your kinetic model.
Old   June 4, 2004, 02:18
Mattias
The boundary conditions are pre-set from measuredments on a real boiler. The mass balance over the furnace i correct. It is the kinetic model that i´m am unsure of. I have modeled the solid fuel as gas and the combustion of gas is much faster than the solid fuel. Is a two-phase model required?
/Mattias
Old   June 4, 2004, 11:32
Ryan Zarnitz
I can't comment on the need for a two-phase model wihtout knowing detailed information about your system, but you could try using the non-premixed combustion model and see if that works better. That works by equilibrium, so you won't need detailed kinetics. Also, keep in mind that air-flow measurement in real boilers is usually not very good, and the burnout stoiciometry for methane is probably different than your biomass, so you may want to take a second look at that.
Ryan
Old   June 6, 2004, 14:32
ap
Well, a bubbling fluidized bed is a multiphase system, so a multiphase model is needed, but reaction and mass transfer aren't available yet in the Eulerian Model.
Hi
ap
Old   June 7, 2004, 07:02
Mattias
The problem is that I have limited CPU power and simulatin a BFB with all that sand in 3D would take enourmus resources. I have developed a corse model to include the heat transfer effect of the sand particle motion through a UDF. Still, the problem is that the fuel is reacting to fast since i´m using the eddy disipation model. I have ahd thought of using the EBU to include Ahrrenius expressions for the reaction.
/Mattias
Old   June 8, 2004, 02:53
Karthick
Hello Mattias
What do u mean by " I have developed a corse model to include the heat transfer effect of the sand particle motion through a UDF". Are u patching the sand temperauture/velocity in your eddy dissipation model? What are u coming to say by "reacting fast". The rate of the reactions all are direcly proportional to the preexponential factor and activation energy which you are giving as input. These values are to be adjusted to change the rate of the reaction.
Regards Karthick
expansion of bed in fluidized bed achy7pch FLUENT 4 April 22, 2024 02:17
Fluidized bed modeling Kartus CFX 9 June 30, 2011 04:41
Fluidized bed simulation VS particle tracking windhair CFX 2 June 28, 2011 21:10
how to define static bed height for fluidized bed mohamad CFX 6 July 28, 2010 14:46
Bubbling Fluidized Bed Sanjib FLUENT 4 April 20, 2002 03:40
