importing solidworks2003 file to gambit 1.2
Old   June 1, 2004, 14:24
Default importing solidworks2003 file to gambit 1.2
utku
Hi
I have a problem about importing a solidworks 2003 3d part to gambit 1.2
I have tried all the extensions but still fails...
How can i import the file?
Finally tried the *.stl and it says "reading ....fidap..." still nothing is seen on the graphic area.
Old   June 1, 2004, 22:35
Default Re: importing solidworks2003 file to gambit 1.2
Arun
Iges is supposed to work without any problem. I am not sure of what the problem could be if you already tried it.
Old   June 2, 2004, 11:50
utku
When i try to import iges file that was exported standart from solidworks, error 5800 happens. I mean doesn't even read the file properties etc.
Selecting generic,solidworks,autocad doesn't seem to handle and still the same error "unable to read file".
The file is a simple 3d fan model and it's not an assembly.
Still i don't get it. Arun thanks by the way...
Old   June 3, 2004, 04:13
Ari
Try to use ACIS(*.sat)file and, if necessary, change the version (under options) when you save the file in solidworks (with GAMBIT 2.0 it works)...Good luck!!!
Ari
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Importing Acis file to gambit Habib FLUENT 5 June 25, 2001 05:19
