June 11, 2004, 05:36 |
explicit formulations
pls tell me what is ment by implicit and explicit formulations.thanks Muhammad zubair asif
June 14, 2004, 00:44 |
Re: explicit formulations
Assalam Alaykum wa Rahmatullah
implicit: For a given variable, the unknown value in each cell is computed using a relation that includes both existing and unknown values from neighboring cells. Therefore each unknown will appear in more than one equation in the system, and these equations must be solved simultaneously to give the unknown quantities. (By using TDMA or any other method) explicit: For a given variable, the unknown value in each cell is computed using a relation that includes only existing values. Therefore each unknown will appear in only one equation in the system and the equations for the unknown value in each cell can be solved one at a time to give the unknown quantities. Hope it would be helpful. Wasalam Mukkarum Hussain |
Explicit method for more than two phases | sachinthakre | FLUENT | 1 | February 17, 2011 12:07 |
Euler (explicit or implicit) | anybody | Main CFD Forum | 2 | May 8, 2006 02:12 |
LES (explicit) filtering | John | Main CFD Forum | 2 | July 29, 2004 18:03 |
explicit formulation | Phonics User | Phoenics | 0 | December 10, 2003 13:07 |
Compressible vs. Incompressible formulations | Fernando Velasco Hurtado | Main CFD Forum | 3 | January 7, 2000 16:51 |
