June 15, 2004, 17:55 |
C/C++ in GAMBIT?
Hey ya'll I'm a beginner in GAMBIT, so my question may sound rather stupid I was said GAMBIT has its own C(or C++) compiler, that allows to parameterize created geometry. I mean, if there are any dependencies between geometrical parameters, I can describe them using C/C++, thus, have less trouble with redrawing the geometry after changing some parameter values. Thanxx
June 15, 2004, 17:58 |
Is this true?
June 15, 2004, 20:36 |
Re: C/C++ in GAMBIT?
I guess ua re hinting towards Journal file. U can check on FLUENTS site. Detialed info is given Podila
June 17, 2004, 03:41 |
That can be done using journal files. GAMBIT always creates a journal (.jou) file when you save your dbs. The journal is a text file which can be modified in order to change the geometry you create running it.
GAMBIT, however, doesn't have a built it C/C++ compiler. Ita FLUENT which has a C interpreter for UDF. Hi ap |
Gambit Startup Window | Jay Shim | FLUENT | 2 | February 12, 2015 14:05 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
Athlon 64 Gambit Compatibility? | Derick | FLUENT | 3 | January 17, 2006 17:28 |
