June 17, 2004, 20:26 |
rake loop with UDF
I try to export data from rakes at different heights in a fluidized bed. My first approach was a journal file to write the data to several files after every 10th time step. But then I run into big problems, because I have about 17 rakes and even with an increased heap size, FLUENT ran out of heap memory after 1000-1500 time steps. Does anyone know, how I can run a loop in an UDF, to get all the values from a rake with 50 points/nodes? The usual loop would be c_node_loop(c, t, n), but a rake doesn't have cells (c) and doesn't belong to a thread (t), right? So how could I do this? I also thought about accessing the rake data through a Scheme command in the UDF, but I'm not sure how to do that. Any help would be highly appreciated! Sebastian |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[CAD formats] my stl surface is seen as just a line | rcastilla | OpenFOAM Meshing & Mesh Conversion | 2 | January 6, 2010 01:30 |
read rake in UDF | Tomasz Bednarz | FLUENT | 0 | June 18, 2008 19:35 |
NACA0012 geometry/design software needed | Franny | Main CFD Forum | 13 | July 7, 2007 15:57 |
rake ID in UDF | Sebastian | FLUENT | 0 | June 11, 2004 20:55 |
