MULTIPHASE MODEL
Old   June 23, 2004, 16:54
Default MULTIPHASE MODEL
Ari
Hi everyone!!!
Is there someone who can tell me if there is a FLUENT version with energy equation available with multiphase model???
Thank you very much!!!
Old   June 24, 2004, 05:56
Default Re: MULTIPHASE MODEL
thomas
version 6.1.22 !
Old   June 25, 2004, 17:40
CFDtoy
Energy Eqns are solved if you require temp profiles. Hence cavitation models ( mixture model in multiphase) would have Energy Eqn enabling option.
CFDtoy
Old   June 28, 2004, 07:55
ap
FLUENT 6.1 (in all subversions) implements the energy equation for multiphase models.
Hi
ap
Old   June 28, 2004, 10:10
Ari
Unfortunately I'm using FLUENT 6.0 !!! Thank you very much for your responses.
Old   June 29, 2004, 10:05
Raja Banerjee
You can still solve energy equation in Fluent 6.0 using the User Defined Scalar equation functionality. Depending on your problem, you might have to write a UDF.
Old   June 30, 2004, 08:51
ap
Yes, you can add the energy balance by solving a user defined scalar equation, which you can implement through UDF.
However, I'd suggest to upgrade, if possible, your FLUENT version because FLUENT 6.1 has many facilities also for UDF which are not available in FLUENT 6.0.
Hi
ap
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
mass balance problem in multiphase model mdsanij1 FLUENT 0 July 28, 2009 16:01
Multiphase model and species transport Reginaldo Cotto FLUENT 0 August 29, 2006 20:36
multiphase model & separation naser FLUENT 5 June 9, 2006 06:12
