VOLUME OF FLUID
Prev Previous Post   Next Post Next
Old   June 17, 2004, 10:44
Default VOLUME OF FLUID
Nial Horton
Dear friend, I am investigating the use of the Volume of fluid method for the simulation of the free surface of flow in a shallow open channel. I have been able to seperate the vel. inlet into two parts to give myself an initial air inlet and then a water inlet at the bottom and am using the PISO function so that the under relaxation factors can be set to one. However, I am having great difficulty in gettin my solution to converge and have found that I am not sure what time step settings to enter.
In this way, any advice or hints that you could give would be greatly appreciated.
Thanks
There is no fluid volume in the project Giron FloEFD, FloWorks & FloTHERM 5 December 30, 2022 08:58
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
fluid hot volume in fluid cold volume zahid FLUENT 4 June 1, 2002 09:11
