accessing a zone
Old   June 30, 2004, 09:47
Default accessing a zone
yobee
Hello!
I know, To access a particular zone, I can use "Lookup_Thread(d,id)" "Lookup_Thread(d,id)" needs domain pointer. But, domain pointer is not passed to the function, which I want to use. In my case, how can I use "Lookup_thread"? I'm simulating one-phase flow.
Thanks.
Old   June 30, 2004, 11:34
Default Re: accessing a zone
Andrew
If you simulating single phase flow your domain pointer is always 1. You can write something like
Thread *thread = Lookup_thread(1, id)
or you could, like I do, create a #define dom_ID 1 at the start and then you write
Thread *thread = Lookup_thread(dom_ID, id)
this way you don't wonder what the odd "1" is doing when you come to look back over old code.
Hope this helps
Old   July 5, 2004, 10:54
Andrew Garrard
Sorry, I miss informed you about this senario. I have only just realised as I made myself some code and realised that I have told you the wrong thing. In single phase flow the Domain ID will always be 1, but when using Lookup_Thread you must provide a pointer, sorry about that. Code something like this should work.
Domain *domain = Get_Domain(1);
Thread *thread_sol = Lookup_Thread(domain, thread_id);
Very sorry for the confusion.
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
Accessing a zone Karthick FLUENT 4 April 16, 2004 00:08
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
