bulk temperature
Old   July 10, 2004, 09:57
Default bulk temperature
Avesta
hi all how do i report bulk temperature from Fluent? please guide me best regard avesta
Old   July 10, 2004, 17:48
Default Re: bulk temperature
AJ
Check area or volume averaged temperature where you're interested in bulk temperature.
thanks AJ
Old   July 11, 2004, 02:09
Avesta
hi dear thank you but bulk temperature is difined as below: T_bulk=integral(UTdA)/integral(UdA) please guide me best regard Avesta
Old   July 11, 2004, 11:59
AJ
As per the definition use custom field calculation to calculate the bulk temoperature for area/volume....
have fun!!!
Old   July 12, 2004, 01:56
Avesta
hi AJ thank you i should define a function as U*T in custom fieldfunction ,then calculate surface integral (integral(u*T*dA) ) ,then integral(u*dA)and then devide them. ok is it correct? because i want to Nusselt number as below definition: Nu=(1/T_bulk)*dT/dr T is non dimentional temperature. IN A TUBE. please guide me. best regard Avesta
plot bulk temperature of fluid mohammadkm FLUENT 4 December 13, 2011 15:37
Bulk temperature Tf is obtained from total or static temperature? NPU_conanxie FLUENT 0 March 30, 2011 05:56
Bulk mean fluid temperature in internal flow mssound FLUENT 0 May 13, 2010 15:56
UDF or any approach for Bulk Temperature calculation vemps FLUENT 0 May 1, 2009 01:09
Bulk temperature for HTC extimation Italy CFX 4 July 12, 2007 00:05
