How to generate this grid???
Old   July 9, 2004, 01:55
Default How to generate this grid???
leoyee
hai everyone:
http://162.105.139.102/LB5000/non-cgi/usr/6/6_5992.bmp
In gambit,how can I generate this kind of grid? I am very glad to someone who can tell me how to do.
Old   July 9, 2004, 07:27
Default Re: How to generate this grid???
ravi
If ths s a 2D problem ----
create a rectangle outer most domain. create the bigger circle. both as faces. subtract the circle frm the rectangle. then using the edge of the holloe circle, using "create face from wireframe" option again create the big circle.
now create the smaller circle and do the same procedure. u got it right !!!! try
Old   July 9, 2004, 14:26
Frank
I have tried it. Thanks.
But the small circle turns to polygon. Can this problem be solved?
[blockMesh] How to generate this kind of grid with slope bottom lin OpenFOAM Meshing & Mesh Conversion 3 January 18, 2011 04:56
How to generate 2D grid of CFL3D in ICEM? aladdincham Main CFD Forum 0 March 11, 2010 02:19
To generate grid for Fastest-3D by ICEM/CFD goni Main CFD Forum 0 September 24, 2007 06:40
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
How to generate grid system with a curved surface Jing Ren Siemens 3 March 13, 2001 11:58
