DPM + Eulerian Model
Old   July 12, 2004, 22:30
Default DPM + Eulerian Model
Shane
Hi all,
I have a eulerian 2phase model with air and water. I want to inject a third phase using the DPM. However the DPM phase is only interacting with the primary phase in the Eulerian model.
Is there a way of making the DPM phase interact with both the primary and secondary Eulerian Phases, or do I have to write a UDF
Thanks in advance Shane
Old   July 13, 2004, 05:36
Default Re: DPM + Eulerian Model
thomas
The secondary eulerian phase represents particles, so do you think it is possible to compute the interactions between 2 class of particles ????
Old   July 14, 2004, 08:26
Karthick
Dear Shane,
I am also having same type of problem. But please tell me whether can we combine DPM and Eulerian model in Fluent? Because both are different multiphase concepts. Can you able to see the particle injections in your model? Please be sure about it.
Regards Karthick
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Two phase Eulerian model with variable solid density ziglat2004 FLUENT 0 September 16, 2011 18:06
Mixture and Eulerian Model Hassid S. FLUENT 1 August 9, 2007 07:24
DPM vs Species transport model osh FLUENT 0 August 19, 2005 22:15
Two phase Eulerian Model Problem senthil FLUENT 5 May 21, 2003 02:55
