negative cell volume in dynamic mesh
Old   July 28, 2004, 10:04
Default negative cell volume in dynamic mesh
WU zhonghua
To Flunet users, i am using a dynamic(deformed) mesh to study flapper valve movement in combustion chamber caused by the difference between the combustion gas and atomisphere pressure. when the program runing, it alaways show the message " error: update-Dynamic-mesh failed. negative cell volume detected error object: #f"
when i do the grid check, it shows in the console: checking face handedness zone 27: 8121 right-handed, 2-left-handed zone 7: 133 right-handed, 2-left-handed
i think the negative cell volume may be caused by the left-handed face handedness appeared in runing. the question is how to prevent this? should i change some controll parameters or remesh the grid? thanks for any suggestions.
WU Zhonghua
Regarding Negative volume detected in Dynamic mesh Vinay Morabad FLUENT 10 December 16, 2015 00:31
Dynamic Mesh - negative cell volume orie FLUENT 1 January 22, 2011 06:05
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Negative volume in dynamic mesh Max FLUENT 1 August 7, 2006 05:18
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
