Two Sided Wall
Old   July 30, 2004, 06:08
Default Two Sided Wall
James Date
Hi
A simple question, when you specify a wall patch within a domain where fluid is on both sides of the patch in Gambit, does Fluent recognise that the wall has two sides with specified slip conditions? or do you have to tell Fluent that patch-id is a thin wall?
Regards James
Old   July 30, 2004, 06:23
Default Re: Two Sided Wall
Sven
My solution to this whas to create two different sufaces in Gambit (lying at approx the same coordinates). Otherwise there were problems i Fluent.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
