Doubt
Old   August 3, 2004, 13:57
Default Doubt
Mukund
Hi All,
Whenever I start fluent (6.1 version), after the license detection I get this message,
Kill script file is c:\temp\kill-fluent3668
I was wondering if there is some problem with the settings or is it ok to encounter this message. Thanks in advance for any views or comments on this.
Mukund.
Old   August 4, 2004, 03:32
Default Re: Doubt
Oliver
Hello Mukund, I get also the same message whenever I start Fluent and I work on an Unix Platform. All of my partners have the same but no one of us knows what is it exactly. The problem is a file generation each time you load fluent.
I'm also interesteed to unterstand why such a message.
Oliver
Old   August 4, 2004, 03:51
Default Re: Doubt
George
Why don't you look for explanation into the file? Easy enough..
George
Old   August 4, 2004, 09:07
Default Re: Doubt
Jason
It's a kill script that Fluent has incoporated. I don't know about any Window's platforms, but on the Unix platform the script is kind of a back-up way of getting out of fluent. If you run the script it will kill the main process and any associated processes it can find. It's easier then going through the ps -ef|grep fluent and killing each command individually. Only time I've had to use it is when the server had a power outage and it disconnected me from the parallel nodes. Hitting cancel tells it to interupt, but for some reason my workstation didn't recognize that the nodes weren't there anymore. That's where the kill script came in. It's all in the file.
On the HP Unix platform type:
more kill-fluent#######
It'll give you all the details on what to do.
Jason
Old   August 4, 2004, 11:28
Default Re: Doubt
Mukund
Thanks to everyone for your responses.
Mukund
doubt about DNS and LES of combustion chinthakindi Main CFD Forum 5 August 17, 2013 11:56
Doubt in Inlet Pressure Boundary Condition Sumitha FLUENT 3 October 20, 2008 03:19
Fluent Basic Doubt Fluent learner FLUENT 16 May 30, 2008 04:09
Doubt on Implicit Methods analyse In India Main CFD Forum 10 March 9, 2007 03:01
les ..small doubt student Main CFD Forum 2 May 23, 2005 05:11
