August 10, 2004, 05:17 |
Text Command List - Change Directory
I am useing the Text Command List in Fluent 6.1. However, when i want to change a directory back to the root directory, and try to do it with "cd .." , like in unix, it doesn't work... How can i get back from, let's say - /display/set/windows/main> To: /display/set/windows It's not clear... Thanks, Lior. |
August 10, 2004, 09:36 |
Re: Text Command List - Change Directory
The Command is "q".
August 11, 2004, 09:36 |
Thank you veru much!
Solid/liquid phase change | fabian_roesler | OpenFOAM | 10 | December 24, 2012 06:37 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 23, 2012 23:41 |
[OpenFOAM] paraFoam not found | maysmech | ParaView | 26 | October 25, 2011 03:14 |
no enthalpy change across the momentum source | Atit Koonsrisuk | CFX | 2 | December 19, 2005 02:33 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
