Shadow phase
Old   August 24, 2004, 12:35
Default Shadow phase
Mansour
Hi all
I am working with two-phase flow (liquid and gas). The system is simple vessel just like simple cup full with the liquid phase with open top surface, and the gas is injected from the bottom through a porous media. The point is that the gas bubbles diameter varies during its journey to the top surface. There is a technique called "Shadow phase" or so used to predict the bubbles diameters variation. However, I wonder if Fluent 6 does support such a technique or on the other hand how does Fluent calculate the gas bubbles size variation.
ManyThanks
Mansour
How to access only one phase in multiphase model by UDF wersoe Fluent UDF and Scheme Programming 1 January 4, 2017 07:11
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
two Phase column simulation chemeng OpenFOAM 3 August 18, 2010 12:53
Source Term used in Eulerian Model(Two phase) Padian FLUENT 1 May 19, 2008 03:47
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
