k-omega
Old   August 4, 2004, 17:03
Default k-omega
Chetan Kadakia
I've been using k-epsilon much in the past, but today I'm thinking about working with k-omega. I understand omega is a function of epsilon (i.e. omega is the specific dissipation rate), and the models may have some advantages over the k-epsilon models. Can anyone add some insight as to how, where, and/or why the k-omega could be more beneficial, and can anyone tell me when how to choose from the standard and from the SST?
Old   August 10, 2004, 07:09
Default Re: k-omega
Bowling
I have ever used standard k-w and sst k-w in mixing layer simulation. I found that standard k-w was not good. The sst k-w was more agree with the experiment data than standard k-w.
Old   September 1, 2004, 17:05
Default Re: k-omega
kamarul
yes, you're right. SST kw performs better because the freestream air does has much influence in the eddies motion. But a standard k-w does.
overshooting of Omega in SST komega using simpleFoam cm_jubayer OpenFOAM 2 June 7, 2020 12:52
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 9, 2011 23:25
Omega at the wall sla FLUENT 0 January 10, 2011 04:16
Use of k omega turbulence model john_w OpenFOAM Running, Solving & CFD 2 September 22, 2009 05:15
Wall function implementation K Omega SSt cbarry OpenFOAM 3 August 18, 2009 10:09
