September 8, 2004, 07:29 |
B.C. for the interface between two volumes
Hello!
I have a question about setting the B.C. How should I set the boundary condition between two volumes(for example solid-solid)? Each volume has its face at the interface. Is it enough to set B.C for one face or should I set for both faces? Or should I unite the two faces? (In my model it would be too much work --a) I would like to know also for solid-fluid interface. Thanks a lot your help! |
September 8, 2004, 07:58 |
Re: B.C. for the interface between two volumes
Hi Kim!
The choice varies according to the BCs features... try to specify them. Ari |
September 8, 2004, 10:04 |
Hello, Ari! How are you? Nice to see you again. How is your work going? I read now UG chap.6 to understand for the setting of BCs. Really, there are many things to learn in FLUENT! When I have any question, can I ask you?
September 9, 2004, 05:56 |
Welcome back Kim!!! My work is going on and I hope to be able to give you some useful advise. Ari
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
[GAMBIT] Connecting volumes | makaero | ANSYS Meshing & Geometry | 4 | April 15, 2010 19:18 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
