reversed flow
Old   September 16, 2004, 01:01
Default reversed flow
Raj
Hi all,
I am simulating a 2D axisymmetrical co-axial burner. The boundary conditions are mass flow rate at the inlets (both for oxygen and fuel) and outflow at the outlet. But i get the message as "reverse flow in faces" and "turbulency viscosity limited to viscosity ratio" while iterating and process was completed in 26 iterations. Can anyone help me out. TIA
Old   September 16, 2004, 09:54
Default Re: reversed flow
Twiti
Try to impose proper boundary condition at the inlet an outlet, and increase the upper limit of the turbulency viscosity. According to my own experiences, you can try a less mass flow rate at the inlets, and increase them to the values you want after you got an initial solution.
Old   September 16, 2004, 22:39
Ng Khai Ching
Hi:
I am developing the 3D compressible unstructured code. When I try to run it in a diffuser, backflow occurs at pressure outlet. Could you pls advise on how to treat backflow? Which variables we need to fix or extrapolate?
Pls help. Thanks.
-khai ching-
Old   September 17, 2004, 02:08
nabeel
hi, in my experience u try outflow condition at oultlet.or give some uniform area at outlet boundary to stabilise flow. nabeel
Old   September 17, 2004, 02:27
Ng Khai Ching
Hi:
In fact, there should be no backflow at the pressure outlet in the converged solution. But, backflow occurs during the iteration.
As mentioned in FLUENT user guide, backflow total temperature is specified. Apart from the total temperature, what other variables we need to fix/extrapolate to avoid backflow in the subsequent iterations?
pls advise.
-khai ching-
reversed flow free FLUENT 4 February 27, 2014 01:56
reversed flow during RNG in turbulence-k epsilon Suman Kandula FLUENT 4 April 2, 2012 07:12
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 04:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 08:05
