Set up the velocity of some cells in the UDF.
Old   September 25, 2004, 07:49
Default Set up the velocity of some cells in the UDF.
Fluenter
hi, all How to set up the velocity of some cells all along equal to zero in the iterations,like the WALL boundary condition?
Old   September 25, 2004, 10:07
Default Re: Set up the velocity of some cells in the UDF.
guru
I thought of sending u a example but this given mail-id doesn't work...
good luck, -guru.
Old   September 25, 2004, 11:27
Fluenter
Thank you, guru. Please try this email address: scubme@yahoo.com.cn
Old   September 25, 2004, 11:51
bob
could you send it to me? thanx a lot!
Old   September 25, 2004, 12:39
Ari
Could you send it even to me ...
Thank you very much!!!
Ari
Old   September 26, 2004, 01:05
sanjay
Can you send it to this mail if you explain it little bit with your code
with best regards
sanjay
Old   September 27, 2004, 01:30
fpingqian
Would you like to send this example to me too? Thanks a lot.
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 18:29
How to set pressure BC with mass Velocity Magnitud arwang FLUENT 2 March 12, 2007 20:04
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
