2-phase surface flow
Old   September 19, 2004, 09:41
Default 2-phase surface flow
stk
Hi! Does anybody knows any other models to handle surface flows except VOF? I see in Eulerian and Langrange model, that i have to put a characteristic diameter in the secondary flow panel, which means that i have to describe particle flow, which i don't want. The reason for asking is that Fluent reports that Dynamic mesh and VOF are not compatible!(i use dynamic). Any ideas are welcome! thanks!
Old   September 20, 2004, 03:11
Default Re: 2-phase surface flow
Frank Meißen
"The reason for asking is that Fluent reports that Dynamic mesh and VOF are not compatible!"
Where does Fluent report this? In our cases it is compatible.
Frank
Old   September 20, 2004, 10:24
stk
Thank you Frank !!I wanted this confirmation!!!! But take a look in Fluent 6.1 Documentation:FLUENT Model Compatibility, and you will see what i mean! i hope that the results of dynamic vof are certainly reliable!
Old   September 21, 2004, 02:19
Frank Meißen
Hello stk,
this is a mistake of Fluent, which was also confirmed by FLUENT support.
Frank
Two Phase Darcy flow with gravity -> problem Cyp OpenFOAM Programming & Development 0 November 17, 2010 07:58
two phase flow + ice phase and breaking soeren87 OpenFOAM Running, Solving & CFD 0 September 19, 2010 10:20
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 08:10
Two phase Flow Ashok Main CFD Forum 0 February 14, 2004 06:37
