sinulate bubble rising with VOF
Old   September 23, 2004, 00:54
Default sinulate bubble rising with VOF
danny
hi, everyone: Now, I am computing the process of a bubble rising thourh water in a pipe. The diameter and the lenth of the pipe is 10mm and 150mm. the bubble diameter is 8mm. If any one could tell me how many grids should the geometry divided?
Thanks!
Old   October 1, 2004, 04:56
Default Re: sinulate bubble rising with VOF
eric
Hi A best compromise is: mesh length = bubble diameter / 10
Old   October 1, 2004, 21:37
danny
Hi, Dear Eric, Thank you for your reply first! But how to choose the lenth width ratio? Is it a square? Thank you!
Old   October 8, 2004, 11:18
eric
I always choose squared meshes. If you want your calculations not to diverge, the mesh has to be as regular as possible. If squared meshes are not possible, try Triangles (same sizes than squared cells) Best regards Eric
bubble rising problem swamysrikanth ANSYS Meshing & Geometry 3 May 31, 2016 11:09
VOF single bubble rising velocity! Lincoln Main CFD Forum 3 April 10, 2012 10:04
interTrackFoam for rising bubble michielm OpenFOAM 3 March 6, 2011 12:27
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 08:59
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 00:02
