Set up the velocity of some cells in the UDF. |
September 25, 2004, 07:49 |
hi, all How to set up the velocity of some cells all along equal to zero in the iterations,like the WALL boundary condition?
September 25, 2004, 10:07 |
Re: Set up the velocity of some cells in the UDF.
I thought of sending u a example but this given mail-id doesn't work...
good luck, -guru. |
September 25, 2004, 11:27 |
Thank you, guru. Please try this email address: scubme@yahoo.com.cn
September 25, 2004, 11:51 |
could you send it to me? thanx a lot!
September 25, 2004, 12:39 |
Could you send it even to me ...
Thank you very much!!! Ari |
September 26, 2004, 01:05 |
Can you send it to this mail if you explain it little bit with your code
with best regards sanjay |
September 27, 2004, 01:30 |
Would you like to send this example to me too? Thanks a lot.
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
UDF velocity and temperature | Raj | FLUENT | 3 | February 1, 2009 18:29 |
How to set pressure BC with mass Velocity Magnitud | arwang | FLUENT | 2 | March 12, 2007 20:04 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
