September 26, 2004, 23:31 |
can't open any graphic window
i can not open any graphic windsows, when i click display(no matter display what), fluent says: floating point error divide by zero, i do not think this is the problem with meshing, because i loaded some good mesh files(working good on other computers) but still have the same problem. Do any one know what's wrong with this?
September 27, 2004, 00:17 |
Re: can't open any graphic window
i appreciate any help and attention, thanks
September 27, 2004, 10:36 |
it is just problem of setting
go to display> view and then play |
September 27, 2004, 11:45 |
in my case it was showing some opengl error.I tried by uninstalling and installing it back again.it did not work. then I installed windows again.it worked.try it.I think some OS file must have got corrupted
September 27, 2004, 13:49 |
Thanks a lot sam and sourav, i found that it is the problem with my video card driver(ati 9600), i changed my driver's setting and finally it worked, if any body has the same problem as me, please click on start-run and type in C:\FLUENT.INC\ntbin\ntx86\fluent -driver msw, this will help you.
October 15, 2004, 05:26 |
November 10, 2004, 09:56 |
I have the same problem. I do exactly the same in my home PC (load a sample grid and display it) and it works perfectly but when I do it gives the floating point error. I suspect it could be due to the graphics card, because the rest is exactly the same in both computers (OS, processor, ...). I haven't found the solution, Just to let you know that you're not alone.
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
