Questions about wall function
Old   October 10, 2004, 23:23
Default Questions about wall function
sarah_ron
Dear all,
When wall function is used in turbulence models, it is suggested y+ is about 30. This point is easy to understand. But in "10.9.1 Near-Wall Mesh Guidelines for Wall Functions", the following statement is difficult for me to understand *It is important to have at least a few cells inside the boundary layer.*
The height of boundary layer is always not known beforehand for many complex turbulence flows. So I am quite confused about this. Any response is warmly welcomed.
Thanks a lot!
sarah
Old   October 11, 2004, 12:02
Default Re: Questions about wall function
Evan Rosenbaum
You may need to modify your mesh after performing initial runs. Assume a near-wall mesh density, and perform a solution. Check the results to see if you have >1 cell in the boundary layer. If no, modify your mesh and try again.
Old   October 12, 2004, 05:02
Mark
Try using the "Viscous Grid Spacing Calculator" found on the the CFD Resources Online page under Online Calculators. This should give you a rough idea of the grid spacing required.
Old   October 12, 2004, 06:46
Helge
To apply the wall function properly you have to use a mesh spacing which follows the known rules (i.e. 200 > y+ > 20). But the second criterion you mentioned has also to be fulfilled. You have to resolve the boundary layer with some nodes. 10 is a good estimate here.
For many flows it is impossible to fulfill both criteria because the boundary layer is too thin. The complete boundary layer or most of it may lay within the first, wall adjacent cell assuming that this cell fulfills the y+ criterion.
In such a case you should switsch to a low-Re turbulence model which does not use a wall function approach. The mesh has to be much finer. Depending on the turbulence model a y+ between 0.1 and 1 will be required.
Old   October 12, 2004, 15:18
hehe666
Dear,
Excellent response!
The quesion is "How to determine the height of boundary layer"? As we know, for lots of complex geometry turbulence flows, there are no free flow like boundary layer flow.
Any response?
hehe
Old   October 12, 2004, 15:22
chenjiansheng
"The complete boundary layer or most of it may lay within the first' How could we know that? I.e. how to determine the bounday layer height even we finish the calculation and get a rough solution? thanks
sheng
Old   October 13, 2004, 09:22
Helge
A good guess would be just to look at the velocity profile near the wall. In the regions of large gradients you should have placed an appropriate number of nodes. This of course only possible after you have made a first simulation.
Old   October 13, 2004, 17:27
Default Thanks a lot
sarah_ron
Dear all,
thanks a lot! I have learned a lot!
regards, sarah
Old   October 21, 2004, 20:22
Default Re: Thanks a lot
Chetan Kadakia
You can also adapt the boundary, if needed. But becareful on your cell counts when doing so. For 3D cells, 1 cell can turn into 8 and 8 can turn into 64, and 64 for can turn into 512...
Old   October 26, 2004, 04:44
Arash
Dear Sir Hi, I want select y+ for k-epselon model in cross over around cylinder, please guide me. Best Regard Arash
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Question about wall function Gary Main CFD Forum 1 December 3, 2007 10:54
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 13:43
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 04:29
