August 16, 2017, 07:06 |
how to change richardson number in fluent??
Mohamad
Rep Power: 8 |
hi . can anyone help me how change RICHARDSON NUMBER in fluent?
my geometry is a T-shaped enclosure. |
August 16, 2017, 08:47 |
Cees Haringa
The same as you would do it without FLUENT.
You have the choice to change gravity, density, or velocity. Of course, do check if other relevant numbers change when toying with any of these. |
August 16, 2017, 09:16 |
Mohamad
Rep Power: 8 |
tanx for helping me. so in ri=Gr/Re^2 , for example i want fix my richardson number at 0.2 . and my Re number is 500 .so i have to calculate Gr number and change density ??
August 16, 2017, 09:22 |
Cees Haringa
If you want to change Ri while keeping Re constant, change gravity (which doesn't influence Re)
August 16, 2017, 10:28 |
Mohamad
Rep Power: 8 |
August 16, 2017, 11:39 |
Lucky
Rep Power: 66 |
Note that changing density will also change the Reynolds number.
Thermal expansion coefficient is a fluid/material property. However, if you choose certain equations of state, it may not be available to you. If you take pressure, temperature as state variables, then the thermal expansivity of a gas and its density are interconnected. You really need to consider what your equation of state is. But in general, changing the thermal expansion coefficient does change the Reynolds number. |
August 16, 2017, 12:25 |
#7 | |
Mohamad
Rep Power: 8 |
August 17, 2017, 04:09 |
Cees Haringa
Well sure you can change the thermal expansion coefficient; again, in principle you can change any parameter present in Ri. However, you should ensure that you are not changing other relevant numbers simultaneously. Since you are planning to keep Re constant, density and velocity are unsuitable. As LuckyTrans states, thermal expansion is unwise, too.
So again, that leaves gravity. What do you have against changing that? |
[snappyHexMesh] snappyHexMesh sticking point | natty_king | OpenFOAM Meshing & Mesh Conversion | 11 | February 20, 2024 09:12 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
