Urgent help
Old   October 18, 2004, 21:52
Default Urgent help
ahourri
Does fluent has limits in its computation? Can't get convergence and mass balance with hydrogen flow (mass flow rate 7e-5 kg/s and velocity 0.022 m/s)in transient mode. My model works with 100 times the same mass flow rate. Any idea will be greatly appreciated
Old   October 19, 2004, 02:47
Default Re: Urgent help
SAM
describe u physicl model
Old   October 19, 2004, 04:27
dumb
use double precision if u think it is a prob of ur value too low.
Old   October 19, 2004, 08:00
SAM
mass is extensve property. unlike the termprature and pressure
please coudl u describe ur problem.i.e physical model, boundary conditions, any assumption. like symetry or periodic
regards
Old   October 19, 2004, 10:33
Satyam
Use double precision solver
Old   October 19, 2004, 14:30
ahourri
My set up is a rectangular configuration with walls everywhere and three windows. One window in the ground is set as mass flow rate, one in the ceiling is a pressure outlet and another one in the front wall as pressure inlet. I am modeling a very simple gas dispersion problem. I am using parallel computers network.
Old   October 19, 2004, 20:11
dumb
mass flow inlet and pressure inlet and one pressure outlet, ... together they seems to be creating problem ... u might want to consider another combination ..or try increasing number of iterations per time step (they should be quite large to get these together workign well) ...
Old   October 20, 2004, 21:04
ahourri
I changed the mass flow rate to pressure inlet which gives 7.1e-5 Pa at the pressure inlet (5.3e-7 Torr). I don't know if the NS equations still hold at that low pressure.
Urgent - Polyflow - particle tracking visualization -Urgent shafaatht ANSYS 0 October 13, 2010 04:56
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
Urgent...urgent...plss!!! astronome FLUENT 0 October 16, 2009 07:17
tmerge urgent urgent jessica FLUENT 4 July 15, 2006 13:37
very urgent pleasade:Cl and Cd values for airfoil Liaquat FLUENT 2 April 27, 2006 12:20
