how to analyze mechanical energy loss of fluid?
Old   October 24, 2004, 05:03
Default how to analyze mechanical energy loss of fluid?
Lcw
As I know, Analysis on mechanical energy loss of fluid(laminar or turbulent flow) has two methods: 1, using experiential formula to compute enengy loss, for example, Darcy formula.This method is often used for engineering problem. 2,using basic energy equation to analyse fluid energy budget. but this method needs numerical computation.This method is often used for theoretical analysis and mechanism research.
Has any other method? or has some review papers on this topic?
thanks
Lcw
Old   October 26, 2004, 19:12
Default Re: how to analyze mechanical energy loss of fluid
par
Do you mean the losses due to the interaction between the fluid and the wall?
Old   October 26, 2004, 21:32
Lcw
Yes, wall is the main cause resulting in mechanical energy losses. we often consider pipe components as local resistance,by introducing a experiential coefficient to compute its loss. Are there any theoretical approach based on bisic mechanical process to solve it?
Old   October 27, 2004, 11:22
par
Hi, in this case you may be talk about viscous losses. As i know it is treated differently depinds on the flow type, ie laminar or turbulent. in laminar flow all you need is to calculate the normal velocity gradient near the wall whereas in turbulent flow you need to consider Reynolds stresses. In fluentI think the viscous is computed using the wall treatment. Hope i gave anything useful Par
How to specify energy source in a fluid zone? abong FLUENT 0 February 17, 2005 02:15
Intl Conf Computational Methods in Fluid Power Jacek Stecki Main CFD Forum 0 November 10, 2002 05:49
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Converting mechanical energy into heat Marat Hoshim Main CFD Forum 3 July 17, 2000 00:30
