Gambit error : Unable to find Exceed X Server
Old   November 1, 2004, 05:48
Default Gambit error : Unable to find Exceed X Server
Jarod
Hi, I get everytime this error message when I try to run Gambit under Windows XP PRO (SP2). I tried to follow the instruction of hummingbird; they say: A workaround that Fluent Support has given is to set the DISPLAY variable to the computer_name.
The following are the steps on how to set the Display on Windows 2000/XP:
- Open up Control Panel - Double click on System - Click on the Advanced tab - Click on the Environment Variables button - Under User Variables click the New button In the Variable text box type: DISPLAY In the Value text box type: computer_name:0.0 (where computer_name is the actual name of your computer) Click OK. BUT IT DIDN'T WORK !!! I got still the same error message: UNABLE TO FIND EXCEED X SERVER. If someone knows how to solve this troubleshooting let me know. Thanks
Old   November 1, 2004, 17:30
Default Re: Gambit error : Unable to find Exceed X Server
frank
i have the same problem and i cant get mine to work either.
Old   November 4, 2004, 06:41
Eric
Hello, I got the same error message but I managed to solve it. My Os is Windows XP PRO (sp2). Let me show you my approach : -Download the Hummingbird Exceed 10 -Install it -run Exceed: Start->Hummingbird connectivity10->Exceed->Exceed. Run cmd.exe, Run gambit.exe with the default command line that you used to do. Unable to find Exceed X server gonna appear but don't close the window and allow your firewall to Gambit access to the net. Normally it'll work ! If not create a value : (The following are the steps on how to set the Display on Windows 2000/XP)
- Open up Control Panel - Double click on System - Click on the Advanced tab - Click on the Environment Variables button - Under User Variables click the New button In the Variable text box type: DISPLAY In the Value text box type: computer_name:0.0 (where computer_name is the actual name of your computer) Click OK. Reboot your computer if it's necessary. Redo the same steps like I said above, that is: run Exceed, run cmd and type gambit. I hope I was clear in my explanations. Hope it will work on your computer.
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 pdilly FLUENT 23 April 2, 2016 12:10
Gambit error: Cannot find exceed x server Jake FLUENT 6 September 10, 2011 11:43
Gambit Default Working Directory Virgil Howardson FLUENT 5 December 19, 2009 06:13
Athlon 64 Gambit Compatibility? Derick FLUENT 3 January 17, 2006 17:28
exceed for gambit 2.2 steve FLUENT 4 July 26, 2005 09:09
