prePDF and moving mesh
Old   November 1, 2004, 21:33
Default prePDF and moving mesh
suailek
hi all,
i am modelling a non-premixed combustion in an internal combustion engine. i would like to know whether the prePDF for non-premixed combustion can be used together with the dynamic mesh in ic engine because when i use the prePDF together with the moving mesh, it gives error. if can what version of prePDF is applicable? i am using prePDF 3 and i think this prePDF 3 is not compatible with moving mesh in Fluent?
Thank in advance.
Old   November 4, 2004, 09:37
Default Re: prePDF and moving mesh
zhzhguo
hi i have the same problem with you, when i use predef to model nonpremixed combustion in inner combustion engine, the console show the message"received a fatal error",i donot know the reasons for this, i guess predef and dynamic mesh can not be used together.
prePDF suailek FLUENT 0 September 21, 2004 07:48
