sliding mesh problem
Old   November 5, 2004, 07:47
Default sliding mesh problem
annie
i want to simulate the unsteady flow of axial compressor. So i must use the tmerge to merge meshes of stator and rotor. I read the merged mesh in Fluent, and want to set the interface between the rotor outlet and stator inlet( rotor in the front of stator), but errors appear: boundaries too far apart.
Who know, what is the problem? The compressor rotates around X axis, in the position of interface, the X position value is completely same. So what is the problem?
Thanks for your help! regards, annie
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
CFX Mesh Deformation problem Silmaril CFX 7 October 19, 2010 10:00
Sliding Mesh Problem CC FLUENT 1 February 8, 2009 23:26
Sliding mesh problem Michel FLUENT 1 January 15, 2009 10:18
