k-w model
Old   November 4, 2004, 13:41
Default k-w model
yee
Hello,everyone I use standard k-w model for my simulation. The residual plot just stay constant even after 2000 interations. But if trying ske and rke model, it can converge after 400 interations.I want to know is there any specific requirement for k-w model??
Any suggestion or help will be greatly appreciated!
Old   November 5, 2004, 03:47
Default Re: k-w model
Domi
Try solving your flowfield for a laminar flow and use that as a starting point for your turbulent simulation. My experience is that the solver works better if you start with a simple problem and gradually make it more and more complex, each time using the solution to the simple problem as an initial condition for the more complex problem.
Old   November 9, 2004, 04:22
Bowling
I have ever used k-w model in my work but I didn't like it. I found that k-w sst model was better. Another problem of k-w compare with k-e is k-w must set less residue than k-e. If you want the goo result.
Hope I can help you. Bowling
Old   November 9, 2004, 17:15
yee
you are rigt. I also found that the sst k-w model is far better than the standard model.
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
