divergence in AMG solver
Old   November 22, 2004, 08:38
Default divergence in AMG solver
Steffen
Hi. I have a simulation of a supersonic-valve running but the program shows me this message: divergence detected in AMG solver: temperature
I tried to rise the limits for temperature and other solution limits but nothing has helped so far
Does anyone what to do
thanx
Old   November 22, 2004, 10:24
Default Re: divergence in AMG solver
Umesh
Try to use more conservative Under-relaxation factor.
Old   November 22, 2004, 12:21
Luca
I had the same problem with a wing in a transonic flight. According to me the segregated solver is not suitable for the conditions with high compressibility. Let me know if you succeed in using the segregated and how... I suggest using the coupled solver,Your problem will vanish... Hope to hear good news from you soon. Luca
Old   November 22, 2004, 19:32
zxaar
this will be something wrong with the either boundary condition or with model selection, generally if things are right fluent just converges fine without any warning or problem. in my opinion these are the signs that you are doing something wrong in settign up the case, look closely
Old   November 30, 2004, 15:37
Aftab
Hi, I have the same problem, and could n't solve it by using the coupled solver. Is there any other possible way. I am simulating office room problem. It seems very simple but on every stage it is creating problems for me. I am going to try to change the underrelaxation. lets see what comes up. Thanks
Old   November 30, 2004, 19:08
zxaar
long ago, one of my friend was doing CFD analysis of a kitchen,, using coupled solver, and he faced the same problem, for some time he din't get the converged results. finally when i looked at his mesh. it seemed the problem is with the mesh not with the solver settings. i suggested him to make mesh more finer, and viola it gave results in one run, without any problem. so moral of the story check your mesh.
Old   December 1, 2004, 08:54
Aftab
My mesh is quite fine, but I will try more finer mesh. Thanks
Old   December 1, 2004, 17:32
parth
then it shall converge ..anyway have you tried using segregated solver, how the results with that
Divergence detected in AMG & FMG solver..... devesh.baghel FLUENT 2 July 30, 2018 22:39
Error: Divergence detected in AMG solver siri FLUENT 8 March 12, 2018 17:08
Error: Divergence detected in AMG solver: species-0 -> Increasing relaxation sweeps ksiegs2 FLUENT 2 June 18, 2012 11:26
Divergence detected AMG solver error Rub Nawaz Khalid FLUENT 2 August 14, 2010 11:01
divergence in AMG solver Aly FLUENT 1 November 11, 2004 13:00
