Modifing grid in Gambit maintaining BC in Fluent
Old   December 17, 2004, 04:16
Default Modifing grid in Gambit maintaining BC in Fluent
DavidS
I´m quite new in Fluent. How can i do to modify my mesh in Gambit and come back in Fluent keeping up the boundary conditions, solver options, viscous options, operating conditions... Thanks a lot
Old   December 21, 2004, 02:53
Default Re: Modifing grid in Gambit maintaining BC in Flue
HP
I think that the best way is to save a file with your inputs (bc's, models, etc.), then modify your grid keeping the same names for your zones (inlets, outlets, etc.). After that open in FLUENT your old cas and dat files, and select the read cas menu command. There you must select the modified grid file. Afterwards you read the bc-file that you had saved.
Notice: In order to save a bc-file use the file/write-bc TEXT command (not menu command), and the file/read-bc to read respectively.
I think that the above will solve your problem.
Regards Ilias
Gambit and Fluent license error message Dimitris FLUENT 11 October 1, 2012 02:05
Fluent, Grid Builing Issue Mark FLUENT 4 March 14, 2008 15:24
Facing Few Problems in Fluent and Gambit Ravi Duggirala FLUENT 5 March 11, 2006 03:13
grid view in fluent nirupam FLUENT 4 February 16, 2006 00:29
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
